3D Printed Starlink Mini Mount for Wingtip
First Flight
“…The parts look good but in order to bring the left flap up enough for it to match the other side I had to remove some metal”
OFF TOPIC:
Past ‘VAF News’ issues:
Starlink Antenna
Has anyone successfully put a starlink antenna in an RV10 I know the antenna will not work thru metal Maybe it works thru the fiberglass canopy? Does it interfere with GPS signals if GPS antenna is on the roof?
vansairforce.net
First Flight
First Flight: Jeff Dingbaum’s RV-14A | Lake in the Hills, IL. RV-14A #140266
https://www.vansaircraft.com/first-flights/jeff-dingbaums-rv-14a/
vansairforce.net
WDYDWYRTW? Thanksgiving Weekend 2025
What did you do with your RV this Thanksgiving weekend? Looking forward to hearing the reports of work progress and motivational flights. v/r,dr
vansairforce.net
Trailering an RV10
I am purchasing an RV10 project. The wings and tail are off, but it is on the gear and complete firewall forward. I have an enclosed race car trailer that would be my preferred way to get it home. I need some help determining if it will fit. My trailer is a 38' long gooseneck, so 30' on the...
vansairforce.net
9A Aileron rigging question
Helping a friend rig his 9A ailerons. We used the special bell crank holder aluminum piece to set the bell crank to aileron pushrods, but after we finished, I noticed something odd. With one aileron set within the limits of the rib tooling hole stick, if I take the stick off and put it on the...
vansairforce.net
Oil leak
I have an oil leak that I believe is coming from the vicinity of the connections on an aluminum block that appears to allow for dual fuel and oil pressure senders. One pair feeds an EIS 4000 and the other pair feed individual gauges. I’m not sure how common this is but it’s what it is. I...
www.vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
