The VAF News - 11.4.2024. #6206. WDYD, Prop Seal, 3D Bit Organizer, CAN bus, LG alignment, Fuse rotisserie, Pmag issue fixed.
DeltaRomeo
doug reeves: unfluencer
Staff member
Pg 1 of 2
dr
cjs
charlesmc
jclark
Dad’s RV-10
RE: CAN bus pulse width and rise times
…N49ex
Moving from theory and datasheet to reality, I decided to actually look at the CAN bus in my plane. I have the typical 22 gauge Tefcel twisted shielded pair wiring, not the special CAN bus stuff, and darn close to the 66 foot limit. I hooked the scope up at the AHARS, which is somewhere in the middle of the bus. Here are some pictures of CAN HI, CAN Lo, and the difference in red. While there are some edge artifacts indicative of reflection components, they are minimal, and noise is really minor. Looks like rise times are in the 66 to 72 ish nS and fall times are 140 to 142 nS. Pulse times are 1 uS and Hi and Lo signals are 1V each. Looks easily clean enough to have no problems. Also measured the twisted pair and determined its impedance is about 67 ohms, and prop delay is 1.57nS/foot.
So, given these rise and fall times and the prop delay of this cable, you can see how Garmin says around 66 feet max, as with the worst case transmitter to receiver delay/distance, the the impedance mismatch reflections end up pretty much absorbed in the slow rise and fall times.
yahugh
Pg 2 of 2
Daily Pic
…Vlad the Awesome
yahugh
RE: Oil cooler shutter: Controllable in the cabin or not?
…Roadjunkie1
Mine is a flap shutter controlled from the cockpit. My cooler is REALLY efficient and I find I have to block off a lot of the cooling air and use the 'waste gate' to fine-tune the temperature from the cockpit. Bottom line: yes; have control of it from the cockpit. IMHO PS: old picture; the nylon nuts have since been replaced with steel.... 😉
Pictures: the cooler set-up; the intake with my Summer air intake restrictor; the Summer and Winter restrictors.
RE: Fuse only on rotisserie?
…lipper03 PIREP
Well I tried and a 2x4 wood structure has too much give and so without more reinforcement, it won't work with just the fuse on the engine stand. So I have jack stands and 2x4s across as temporary supports on the back for now, and waiting on a hydraulic lift cart to get me by until I do the big join. I figure I'll just adjust the lift cart as I rotate and work in the meantime.
If one doesn't want to do the cart (about $200), you could make some supports, to set the rear of the fuse on. You'd need at least two heights, one for horizontal, one for rotated 90 degrees.
Advertiser Sale
…Pmerems
Pmag Issue Resolved
…bkervaski update
Resolved my issue, harness had a resistor, removed it and everything worked as expected.
OFF TOPIC:
