Runway Re-Sealed at 52F
….my home field. Currently closed. Should be painted on Thursday. We *think* open Friday. v/r,dr
Garmin’s New D2™ Mach 2
...Note Nearest Airport at top of 2nd image below. Cool. dr
OFF TOPIC:
Cowl hinge offset on RV-12is - edge clearance
Page 37is/U-09 calls for the MS20257-3 cowl side hinge to be offset 1/16" up from the bottom cowl edge. Doing that leaves 7/16" of leaf overlapping the bottom cowl fiberglass. That allows for 1/4" rivet centerline to fiberglass edge (~ 2.5*Rd clearance) and 3/16" rivet centerline to leaf edge...
vansairforce.net
F1 FWF Taking Shape!
I have been spending a fair amount of time getting the firewall forward work done on the F1 Rocket project the past couple of months, mostly because I want to be off the fabrication workbench and have the aircraft in the assembly area of the shop when Louise’s RV-15 wing kit shows up! Progress...
vansairforce.net
Nose tire replacement woes
I decided to replace my nose wheel tire while doing my annual and after 2 tubes pinched I am ready to go nuts. I have don’t the change before but not sure why I am having so much trouble this time. I have the Anti Splat sealed bearings mod. The tube has pinched both times between the wheel...
vansairforce.net
Case Bolt Torque
I’m at that point in the Baffling chapter where they have you attach some fittings to three of the top case bolts. Where can I find the correct torque values for those bolts? Thanks.
vansairforce.net
First Flight: Ross Anderson’s RV-7A | Richmond, VA RV-7A #74714
https://www.vansaircraft.com/first-flights/ross-andersons-rv-7a/
www.vansairforce.net
Ground adjustable prop ……Cato vs WW
I am trying to decide which ground adjustable prop to use on my 180 hp RV7. Cato at $6200 vs WW at $4700. Is it worth the extra $$$ for the Cato? Am I missing any other options? Looking for the best quality/performance prop. Thanks for your input on this dilemma Steve
vansairforce.net
Torque Delrin Block Bolts?
I'm actually not sure it's made of Delrin, but I've noticed that for the white colored plastic blocks that are for support of things like the flap weldment supports, if I actually torque the bolts to a normal spec it tends to deform/squish the blocks. The black blocks seem a lot harder. Should...
vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
