Thanks again to those readers helping keep this small business online with a badge under their username! I appreciate you very much! You folks help keep the lights on…..quite literally.
And thanks again to everybody keeping everything so polite per the rules. You make it a rare place.
v/r,dr
OFF TOPIC:
v/r,dr
Mud & rock guards
Want to know if anyone has bought or built rock mud guards for an RV (and especially an A model)? I was at Canyonlands, Utah (KCNY) and saw these on a Cessna: Currently easy/fun to fly into Johnson Creek, Garden Valley, Cavanaugh Bay, etc. with the wheel pants, but would like to go to Big...
vansairforce.net
My RV-12iS Paint Job
Showing off my RV-12iS paint job that John Stahr and I did in my hangar a couple of weeks ago. I built a 12' x 24' booth and we painted her in 7 days! Definitely worth all the work! Get in Touch with John Stahr if you want a beautiful, unique airplane! See the cover of this month's Sport...
vansairforce.net
Manual Vernier Trim Threads
I'm planing to convert to electric trim and as part of that going I'm to make an adapter for the Ray Allen T3-12A. I'm going this route in the event I don't like the electric trim and I can easily swap it back and forth between them without changing the cable. However, what are the threads...
vansairforce.net
Rolling rudder leading edges rv8
I am having issues with rolling my rudder leading edge I didn’t have to much issue getting the top and middle sections to pull to together but the lower one has to be stretched quite a bit. I am using 1 inch O/D pvc pipe to get my rolls. Any help on correcting this would be appreciated.
vansairforce.net
Stacking Lightspeed controllers with standoffs?
Hello! I'm using dual lightspeed ignition and working on placing the controllers. I didn't have really anywhere else workable other than the forward baggage area on my RV-8. I would LOVE to be able to stack the controllers to save space, but it seems like that might not be possible? The...
vansairforce.net
Silicone hose for cylinder drainback?
Textile reinforced rubber seems to be almost universal for cylinder drainback. Has anyone tried high temp silicone (maybe reinforced) instead? Is there a specific product or source you've used and recommend? Edit: I'm reinstalling baffles soon and want to take care of it before they get hard to...
vansairforce.net
Help! - Marvel Carb MSA-4SPA stuck Power Jet Gasket
I swapped out my power jet nozzle with another one that was drilled to allow more fuel flow, and I thought I had lost the felt gasket (52) at its tip. Checked inside the carb which houses the nozzle section and I don't see anything. I install the replacement nozzle with a new felt gasket. The...
vansairforce.net
Engine Mount Bracket - Tight Fit
Hi everyone. so I have just made the jump from wing building to fuselage building - yay me - and of course you start with the firewall. All good, except when I go to trial fit the lower engine mount welded steel brackets, they clash with the aluminium stiffener - see photos below. If I...
vansairforce.net
E-04 406 ELT Remote audio corrosion
This was the year to replace the batteries in the remote panel and audio panel. Been flying for 6 years now. The remote panel was fine but audio panel was corroded so badly the metal disintegrated. Came across this 2019 advisory from ACK issued 2 months before my first flight ACK battery...
vansairforce.net
WDYDWYRTW? Oct 18-19, 2025
Not a lot of RV activity around DFW this day. Hope better where you are. v/r,dr
vansairforce.net
RV-4 #4175 Fastback Conversion
My 4 is down for a bit for a several little projects, like elevator reskinning due to some cracking, adding a light to the tail, possibly electric trim, fiberglass repair due to some less than perfect fits over the years, etc. While it's down, I decided to make it way worse for time and money...
vansairforce.net
OFF TOPIC:
vansairforce.net
www.vansairforce.net
vansairforce.net
