Wishing you and yours a happy, safe and RV-filled weekend!
v/r,dr
ShawnR
https://vansairforce.net/threads/engine-alignment-with-new-engine-mount.230271/
HFS
….a simple extension.
https://vansairforce.net/threads/maintaining-tire-pressure-with-wheel-pants.213476/post-1797756
Jimzap pic:
DaveJ
Steve Ashby
Jonnyb
Penquin’s heavily mod’d 6 cowl
I don't know anyone offering this kind of thing for sale.
This is the size of hole I ended up with, started with regular RV-6 cowl with a scoop.
Kooshball
OFF TOPIC:
v/r,dr
ShawnR
HFS
Jimzap pic:
DaveJ
Parker 212FB Rolo-flair
I purchased this tool new at airventure this summer and am now starting to build fuel lines. I question the small arm that pivots across the end of the tube to set tube length from the dies. This length setting arm on my tool is not flat where it registers against the end of the tubing, it...
vansairforce.net
Steve Ashby
Making a decision about Basic Med and insuring my RV-8A
I have researched the forums and can’t find a definitive answer. I would love to hear from my RV brethren (and/or sisteren) about how to proceed. Going back 2 years ago, I was flying my C-172 under basic med when I had a cardiac stent. I then had to reapply for a class 3 with a special...
www.vansairforce.net
Jonnyb
Seat rib to centre section
Can I ask what people have used to set these rivets?
air intake system
I have and RV-8 in the build process. It is an angle valve IO360 with a horizontal induction and Fly efii system 32 set up. I would like to know what intake/filter systems other builders have installed. I would like something similar to a Rod Bower type 2 set up but not necessarily needing the...
vansairforce.net
Kooshball
Engine won’t run on the right mag after installing tach pickup, troubleshooting help needed.
I am looking for suggestions on an ignition issue that just showed up after replacing the tach pickup that is installed in the inboard vent hole of my slick 4370 mag. The mag was overhauled ~15 hours ago and the last time I flew before annual, it worked fine. This mag is on the right, and I...
OFF TOPIC:
vansairforce.net
