Looks like an icing event in N.TX and eastward on Thu / Fri. Plan accordingly.
md9680 RV-14A
3D Printed Wheel Chock ….dr
Dan 57
maprkelliott
SkyDweller Alternator Update
“As an update, someone on here suggested checking for grounding. Through that process, I found that the terminals for the cable grounded to my engine block were very loose. They were wiggling inside of the terminal and one pulled out of the terminal quite easily. Since using a hydraulic crimper to rescue terminals I have been unable to recreate the issue. Hoping it was in fact that simple!”
OFF TOPIC:
Heavy Icing Possible DFW to Alabama, Thursday, Friday
Newest 60 hour forecast. If you live in North Texas, you may want to take steps to protect your airplane and the water pipes in your hangar, etc.. The last round like this ended up with dozens of pipes rupturing at our airport. v/r,dr https://www.wpc.ncep.noaa.gov/basicwx/basicwx_ndfd.php
vansairforce.net
md9680 RV-14A
Page 14-7 Question
On page 14-7, the trimmed outboard rib is only clecoed. When does it finally get riveted to the spar? Thank you.
vansairforce.net
3D Printed Wheel Chock for my RV
…playing around with some software and knocked this out in about 15 minutes while the wifey was watching Law and Order. I’ll print one, and if it fits under my wheel pants I’ll print the other five. I’m finding this a fun way to mod the RV experience while resting in the evening chair...
www.vansairforce.net
Dan 57
Hotter in front, or in the rear of the top engine baffle?
The subject of T on top of the engine has already been discussed a couple of times, but in regard to injected engines and their respective spider location. My engine has purred happily for 20 years, producing 2.2K hours of unaltered pleasure, and is actually being replaced by a brand new...
vansairforce.net
maprkelliott
B&C BCS206 starter on IO-390 with Avstar fuel servo
BCS206 starter will not fit the IO-390 with the avstar fuel servo as the throttle body bolt as indexed hits the back of the starter. Has anyone found a fix for this? Just to be clear, it isn’t the throttle linkage - it’s the roll pin index to the idle stop. There isn’t enough throw. The...
vansairforce.net
PlanePower Alternator Alternative?
I have the Plane-Power AL12-EI60/B on my IO-360-M1B. I consistently see 14.4v on the SkyView EFIS. From the Plane-Power FAQs: Thanks for the correction. Good to know.
vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
