Haven’t replaced the fuse holder but I did change to the EarthX battery in April. Can’t imagine that would have anything to do with it, but the prop does spin noticeably faster when hot as opposed to cold. Could the SureFly mistake the engine already being at idle and no longer in start mode? Seems to me like it will only fire when the battery is nearly depleted as it did on Sunday. Just a hunch at this point. And the first SIM seemed fine with hot starts using the EarthX. Ill keep digging.
Interesting thought, you might be on to something. Someone else experienced a similar hot start problem in 2025 and this theory was proposed. Unfortunately the OP never posted about resolution:Could the SureFly mistake the engine already being at idle and no longer in start mode?
However Surefly SIMs adjust timing during engine starts, it requires a change to my hot start procedure
I recently had to do a couple of hot starts with my dual SIM equipped IO-540. Having no luck with my normal methods I found that running the starter through 3-4 blades and then returning to the run position seemed to give me an easy, Instant start. At first I thought it was just luck but I’ve...
vansairforce.net
It seems a few folks believe the SureFly engages start-timing retard below 250RPM. Are you able to measure your hot-start RPM with an independent instrument? Confirming the retard cut-out RPM with SureFly would be a reasonable next step.
