SOLD RV-6A
Eric Petersen
Member
Benefactor
Sponsor
RV Model: RV-6A
Quick Build (QB) or Standard Build (SB): Standard Build
Slider or Tip Up: Tip Up
S/N: 22472
Asking Price: $90,000
IFR/VFR: VFR
Why selling: Moving on…
Total Time (hrs) on airframe: ~482
First flight date: July 22, 2008
Original Builder (y/n)?: Yes
Empty Weight (lbs): 1043
- CG (empty weight - inches from datum): 69.4
- date of last weighing: 2008 (needs updating)
Year painted: 2015
- Painted by: Midwest Aircraft Refinishing
Engine Make/Model: O 320 D1A
- HP: 160
- Total Time Since New (hrs): ~482
- Time Since Overhauled (hrs): na
- Ignition: Left Surefly, Right Slick mag
- Carb/FI: Carb
- Exhaust system: Vetterman
- Engine Purchased from: Vans
- Engine Assembled by: Lycoming
- Date of last compression check: Sept ‘25
- - Cylinder #1: 76/80
- - Cylinder #2: 76/80
- - Cylinder #3: 77/80
- - Cylinder #4: 77/80
Prop:
- Make (FP or C/S):
C/S
- Model: Hartzell C2YL-1BF/F7663-4
Flaps (manual / electric): Manual
Rudder Trim (manual / electric): na
Elevator Trim (manual / electric): Manual
Aileron Trim (manual / electric): na
Strobes Make/Model: aeroflash
Age of tires/tubes: Mains 2 year
Nose tire 2 year, tube very old (pinched new one on install)
Avionics:
Icom A-200
- Garmin 320
- Garmin GDL 82 adsb out, Garmin GDL 39 adsb in
- Garmin Aera 660
- Rocky Mountain Engine Monitor
- Dynon D-10
- TruTrak Digiflight autopilot
- Lift Reserve Indicator
Interior: Flightlines
Past incidents/repairs/damage repair: none
Service bulletins/Change notices that have been complied with: All
Date last annual: Sept 2025
- Maintained by: Seller
Date last transponder check: Apr 2025
Date aircraft last flown: 06/20/2026
Other items not listed above:
All new hoses by TS flightlines – June 24
B&C 40 Amp Alternator
Contact Info
- name:
Eric Petersen
- voice/text: 612.860.2146
