My experience with RV7a horizontal induction was the B&C will not fit without significant snorkel modification. I opted to switch horses and go with skytec NL model which is more robust than the lightweight skytecs.I've just ordered an IO-360-A1B6 from Aerosport Power and it occurred to me that I'd better check on the snorkel fit around the B&C starter. Does that combination fit well or are guys using the SkyTec unit? I still have plenty of time to switch starters if necessary.
I did the same for my IO360 M1B in my 8 since the B&C wouldn't fit.My experience with RV7a horizontal induction was the B&C will not fit without significant snorkel modification. I opted to switch horses and go with skytec NL model which is more robust than the lightweight skytecs.
Got it. I was planning on battery in the back and oil cooler on the baffle, just like last time. The w&b turned out so well back then that I’m really just trying to duplicate its performance and feel.B&C has a 60amp alternator with built in regulator.
I have seen an 8 with a remote filter on the firewall. It is doable. It just depends how you lay everything out...ie battery on the FW or in the back, oil cooler on the FW, mtr mt or baffle etc.
I seem to remember someone on here discussing a new snorkel design that Vans was working on, (presented at Oshkosh or something?) that would not only clear the starter but give more HP as well. Not sure how old your kit is but it may be worth an email to vans to find out which snorkel you have.Got it. I was planning on battery in the back and oil cooler on the baffle, just like last time. The w&b turned out so well back then that I’m really just trying to duplicate its performance and feel.
It does need a small relief but it does not impact the performance; I get the same MP and numbers before and after modifying mine to accommodate the larger diameter body.I've just ordered an IO-360-A1B6 from Aerosport Power and it occurred to me that I'd better check on the snorkel fit around the B&C starter. Does that combination fit well or are guys using the SkyTec unit? I still have plenty of time to switch starters if necessary.
