I’m installing the Garmin AP servo in the pitch location on my 14, The bellcrank bearing center to the pre drilled hole for the servo arm connection is 2 3/4 in. Looking over the G3X manual on the model 10 drawing, that hole is at 2 1/2 in from center. Garmin does not have model 14 data I can find so far and Vans tells me it should be same as 10 model. What have you done in this install?
