RV12iS fuel pump 2 offline
mtw1212
Member
Friend
Normal startup yesterday afternoon, but when turned on fuel pump 2 light didn't come on. Turned off pump 1 to verify 2 not working. Cycled number 1 & 2 a couple of times and then 2 came back online. Could not repeat 2 being offline again. Both pumps were working at the conclusion of previous days flight as I verified prior to shutdown. Didn't fly & rolled plane back into hanger to resolve issue.
I haven't completed SB-58 HIC module replacement yet & wondered if this was possible issue?
Todd Wilemon
N748BR
Yes that is most likely the issue. I had the same problem and SB 58 took care of it.
You may want to do SL 00072 at the same time or at least have the part handy.
