Hello fellow RV'ers:
So when I turn on the master swith, the two ignitions and run the engine/props, the battery does not show charging. The main battery is almost new, and have no issues starting the engine. After which, would assume alternator takes over and should be charging the battery. But its not, and the volts subsequently drops below 11.5v.
Any thoughts?
I pulled then pushed back back in the generator master fuse with no noticeable effect.
Think its regulartor or some other issue?
Regards,
Monir
Any thoughts?
Regards,
Monir
