gmcjetpilot
The point of the thread is educate me on LSA's by those who have been more involved. In particular you RV-12iS owners you experience in transitioning, ownership. What you think in general of other LSA's comparatively. Also share observations of transition training I gave recently. Last what are pros and cons of LSA and the future of LSA. **
Just had the pleasure of flying an RV-12iS for 6 hours, additional pilot during Phase 1 and checking out the builder and owner.
I can say the pilot did have some learning, with stick, glass cockpit and no nose wheel steering, plus flying a plane 1000 lbs lighter than Piper Cherokee 180 he flew.
He did struggle a bit with taxi, takeoff and landing directional control with cross winds. That is my Pet Peeve, and find many pilots never learn, forget, master cross winds.
A plane with nose steering does cover up lack of proper control inputs in winds. Fortunately we had lots of windy days with cross winds. It took about 6 hours.
On the last day it was calm and he was landing very well. If he does not practice and stay current he could regress, we all do if not current and practice.
He is flying solo and consolidating his training as required for 5 hrs with no passengers.
LOC (Loss of Control) is the one of the biggest factors in mishaps for all planes. I find RV-12 is easy to handle. But as I said to him "RUDDER RUDDER RUDDER!" once or twice.
It is not much unlike going from nose wheel (with steering) to tail wheel plane.
You have to anticipate the weather vane and LEFT turning tendency as you add power. If you let it head off to the weeds at slow speed it can be corrected but more work.
At 6 hours he was getting it, consistent and making nice landings.
TRANSITION to stick, responsive controls, trim use, free caster nose wheel, Rotax preflight operations, G3X was emphasized. Overall it flies nice with out any bad habits, but takes time, practice. NOTE The Additional Pilot Program, per AC 90-116 is something every new RV-12iS pilot should use. The additional pilot does not have to be a CFI, but must have experience in make/model series, currency.
DO YOU HAVE ANY OBSERVATIONS OF YOUR RV-12IS TRAINING TO SHARE?
I am RV-4. RV-6, RV-7 owner, builder, pilot for +30 yrs. CFI and ATP. All RV's share the Van's "Total Performance". Never built or owned an RV-12. The RV-12 does have Van's characteristics but at the same time different than other RV's for sure. It's a 100HP LSA not a 200HP RV-7. I can say scooting along 115kts true @ 4 to 4.5 gal.hr is nice on wallet.
Caution, WARNING. The TRIM is very effective. One of the first RV-12 accidents long ago on 1st flight with two people, loss of control on take off. They lost control due to too much nose up trim. I was aware of this. I even briefed the pilot early on. When doing T/G's be very careful to assure flaps and trim set. One T/G the pilot popped off ground with trim set for landing. He was not correcting by lowing nose fast enough for my comfort and had say LOWER PITCH and guarded stick. No where near stall but a good lesson learned for him an me. I did not double check, but hey it was fine the last 15 T/G's. I would love the G3X show the flaps and trim more prominently and add AUDIO in transit sound. I think it would add situational awareness. Again pilot is getting use to glass. The size, color, location of flaps and trim indication are a bit overwhelmed with the other lager color coded information and data. It is a matter of knowing where to look and to look every time.
PERSONAL DISLIKES
Burping the ROTAX. Not a big deal but it's a thing. Ha ha.
Location of Throttle between seats and pilot and co-pilots thighs.
Location of Flap Switch between seats and pilot and co-pilots hips (below seat cushion level, kind of burred.
Stick Hat Buttons, (4) on top: trim up, down, A/P disconnect and FREQ FLIP. 1 PTT Fwd side. Pilot inadvertently switched off active Freq a few times.
Curious what you think on how the RV-12iS compares to other low ( or high wing) LSA's, aspects, cost, build, design, performance, specifications.
I have studied LSA's over the year since the early entry into the market. I was not impressed at first (20 yrs ago) and tried to ignore them, but they have come a long way.
Cheek list he has does NOT have FLAP SET. He did full stop and we went into airport terminal for break. Back in plane he asked should he do full runup. I left it up to him (you have to see what pilots do). He elected to do partial pre-take off and not do runup. He read the check list and did not really look and check. He said "ready". I said no. I said do the check list again. He saw trim was not set, but glazed over the flaps. FLAPS IS NOT ON CHECK LIST!!! We hand wrote it in. I AM A FLOW GUY CHECK EVERYTHING THEN DO CHECK LIST. Also I caught him reading and not looking. Check list is READ, LOOK, INTERPRED STATE (On, Set, check). You can say it out loud or say it to yourself. As a CFI I like pilots doing verbal call outs so I know. Airlines use call outs as SOP. Mandatory. Many pilots use check list as a read and do. I like a flow top to bottom, left to right, front to back, check and set everything. Then run the CHECK (not do list). Reading heads down not checking with eyes and or hands is pointless.
LSA, SLSA, ELSA, & E-AB Aircraft, rules can be a bit convoluted or unique. With MOSAIC there may be a mLSA” Sector or category.
Many so called LSA's in past were not, because the industry is self regulating. LSA's are NOT FAA certified, but FAA knows about the past deviations.
You know if you buy Van's RV-12iS or build to plans, it will be compliant. Again with MOSAIC who knows. It will open up many more planes as LSA's.
For now dealing with what LSA is currently is enough fun.
Van's and Zeneth are leaders in LSA kits. I blinked and saw a list of over 150 LSA's, most never heard of. Many I suspect are defunct.
Wiki list is more current with about 40 S-LSA and E-LSA kits, airplane, amphibian, rotary, glider.
I have stood next to (not flown) two S-LSA's, Vashon Ranger (IO-200 continental) and the Aeroprakt A-22, (Rotax 912). Both high wings. Nice designs and build quality.
Other approved E-LSA kit planes, Kitfox, Cub Crafteres, Searay, SLING. S-LSA turn key many and not cheap. Std category Aeronca 7EC (certified to lower gross) is a "LSA".
S and E-LSA's have to be ASTM compliant, including engine. A Rotax (burping oil), Jabiru, and Continental 0-200 typically. There are other engines ASTM approved. If you go with experimental engine (Viking) it will not be a E-LSA but an EAB.
What is your thoughts on RV-12iS likes and dislikes, cost to build, insure, how do you think it compares to other LSA's, and thoughts on future of LSA? **
One of my LSA pet peeves is cost. The pomise of cheap flying really has not materialized at least on price of airframe side. ICON A5 anyone? Most if not all S-LSA's are north of $100,000. To even build an E-LSA RV-12iS fully kitted out is pushing $100K. What did it cost you to build an RV-12iS? Yes LSA pilot training less, maintenance less (taking 2 Day LSA inspection class). Fuel burn yes, but you have to fly a lot make this a huge factor, say you save 400 gal a year flying 100 hrs. A RV-7 is 50 kts faster, so on a MPH basis about $1350 per year based on $5/gal.
. A RV-12iS without wheel pants is not exceptionally more efficient. The Rotax is a bit (but not a lot) more efficient in spacific fuel consumption than a Lycoming. However WOT and full rich a Lycoming is a gas hog. The Rotax is always optimized. But if a good pilot flys their Lyc powered RV-7 in economical way the difference is not that great HP to HP or speed vs speed/
The last is no medical? Basic medical makes this less of an advantage but it's still a nice thing. But if I am sick, have health issues, which I don't, but if I did, I am not flying no matter, LSA or no LSA. On the positive is they are fun, safe, fairly fast, matching typical SEL stannard category aircraft speeds (but not passengers or payload), at about 30% to 50% less fuel. The cost of hanger, insurance will be equivalent. What do you pay for RV-12is insurance? I have heard $2000 or $3000 (not sure) for $80K value?
** MOSAIC, Right now I am ignoring it until it is finalized. The Drone Remote ID thing was embarrassing but now in affect as of March 2024. As a remote UAS Part 107 pilot I need to buy remote ID equip to attach to my drone. At least you can buy remote ID's. Last deadline the equip to add on to existing drones to comply was all but nonexistent. I guess my RV-7 will be a LSA now? Can't be bothered until the 2025 when proposed ruling is made law. I think they bit off too much, with unintended consequences yet to be realized, so it may take longer. If they expand the LSA category , how will that be implemented, in actual practice is a mystery to me . LSA is already an odd cutout in existing FAR's in every aspect. The increase in LSA performance (weight, stall, top speed, CS prop, retract) is spectacular. The stall speed will be limiting factor. Any plane that can push the proposed new LSA limits (weight, top speed and have low stall) will defy current physics or at least all current designs. Bring it on. I want a 3000 lb 250kt LSA that stalls at 54kts or less while burning 4 gal/hr and can be bought for $60,000. Ha ha. I will wait. It does not affect me (yet). I am excited to see what planes qualify or are created that exploits the new parameters. For sure it will not be cheaper. Is it all good and will make flying safer, cheaper, easier to obtain. May be? May be not? For sure the new rule if implemented as proposed will be a huge disruption to the industry and GA, for the better I hope.
PERSONAL DISLIKES
He may disable button. I'd consider double side sticky tape on a guard, so button is recessed slightly. COM is important, safety & complying with ATC, not trivial.
On my plane the trim, flaps and A/P disconnect are on panel near the throttle. I can keep hand on throttle for trim. Only stick button PTT.
