Just did SD-00001 Trim motor Safety Directive. All I had to do was add BUSHING, the tray and motor were in compliance.
Than started started getting the trim up or trim down with autopilot on message. If you manually trim A/P disconnects (as you should).
I did the trim calibration, and I loaded new new G3X Firmware. It is better and now the trim up or trim down only flashes for a moment.
Did NOT update the RV-12iS VFR Avionics w/Rotax 912iS, Autopilot (AFCS) Settings RV-12iS G3XT Autopilot Rev 3. Reading the update it does something to trim. This is the next step.
Does anyone have some tips or tricks to trouble shooting, had similar experience.
