RV-10 AOG at KLEM
Weefle
Tried leaving this morning for KSBX then Canada . Got :5 minutes out and oil temps went to 226 and climbing rapidly with oil cooler wide open. Returned to airport. Mechanic thinks it’s a vernatherm. Only 140 hours on engine. Can they fail this new?
I have the upgraded cooler and it’s never done this in the past.
Any help appreciated. ACS has one in stock but may have to sit here till Monday or Tuesday.
K
K
getting to 225 in 5 minutes seems a bit suspicious if no squirters and 540's usually don't have them. do you reemember the temp at take off? have never really paid much attention to how quickly i get to 170, where i believe the VT starts moving. i will get to 190's in the climb in the summer, so cooling clearly required. piston squirters totally changes things and OT can get out of hand at pattern alt with poor cooling.
No squirtters o this engine. Temp read out at start up was ambient. Then in the climb it started getting over temps what I normally see. If I could access the internet I’d upload my data to flysto and have more accurate data. Things happened fast and I was trying to pick up my clearance etc.
Mechanic has a VT that we are going to try. Just have to R&R the old one and see what happens.
K
…. rapidly with oil cooler wide open.
Above statement makes me think you have a controllable shutter for the air to the oil cooler. Saw the exact same symptoms once with a new-to-the-airplane pilot who inadvertently had hit the not so well marked control knob, and closed the shutter. First thing I’d check is the shutter is open?
K
I hope that the vt works for you. Please let us know if that works. I wonder if temps can really climb that fast and this could be a learning experience for the rest of us.
Plus those firgelli linear actuators have a pretty short life expectancy in FWF applications in my experience. I changed all mine back to cables after 2 failures. This potential scenario was the motivation.
Tested the original VT. It’s expanding like it should. Shutter is wide open no issues with the linear acuator either.
We’re scratching our heads. Looked into where the VT seats. All looks good. Looking at the bypass for the B&C oil filter adapter.
This has got to be a pilots worst nightmare. Trying to get home from EAA Airventure and now this.
Were your oil temps bouncing or steady?
I had a sensor failure a couple years ago. Bouncing around red to green to red to yellow to green to red, etc. oil doesn’t change that quickly.
Oil temps steadily rose. No bouncing around. We just checked it with hot water and shot the mug with an IR heat detector within degrees of each other. Then used a heat gun to watch it climb from ambient to 230+ and it was rock solid.
CHT normal? Oil qty normal?
My CHT on TO always higher on number 2&4…. It got up to 425 until I lowered the nose and added some mixture.
Oil at 7.5 quarts.
This is so weird. Never had this issue last year in the Okanagan heat. And this happened at 8000’ yesterday in cruise.
Another thought:
Is it the TCW butterfly? Or a different “shutter”?
If it the TCW have you verified with the scat off that the butterfly is in fact moving? The control arm friction lock in the butterfly axle isn’t particularly robust and has no mechanism other than tightening the grip nut. If this loosens then everything will look like it’s working as designed but it isn’t.
My TCW from the factory wasn’t great. One of the holes was oversized such that the snap bushing wobbled around in the hole excessively.
I wasted a lot of time generally with that whole setup. One of these things that seems like a good idea on paper but in reality the juice wasn’t worth the squeeze.
Quite a head scratcher indeed if the VT is ok. Hard to think of much other than a blocked cooler / low oil.
Another thought:
Confirmed the shutter is functioning properly. The linear actuator operates as it should. I also have a stop installed so it cannot over center from airflow and go closed .
Thanks for all the tips thus far!
Oil at 7.5 quarts.
Which is it? Were you climbing nose high and mixture leaned? Or in level cruise?
It seems like someone had a similar problem a while back ago and it turned out to be a blockage in one of the oil cooler hose fittings at the engine if I remember correctly. It was a weird problem for sure and the guy troubleshot it for a long time.
