This measurement may be different between planes as each plane may have their rudder set-up with differing max degrees of deflection.
Best to get in there & measure your set up. You could get some adjustability by shortening the length of the forward links between the rudder cable & pedal. Note that the shorter the link, the more aft angle of your rudder pedal & could make brake pedal activation (angle of foot) tougher.
