FYI, we have published an update to the Kit Assembly Instructions (KAI) for the RV-12 and RV-12iS, which includes changes to the install sequence for upper 90-degree fitting on gun-drilled gear legs.
Before this change, the plans called for the installation of the fittings at a point that required some disassembly, which is clearly far less than optimal. The updated plans now specify installation of the fittings at the proper point to avoid this problem.
Here are links to the revised sections for both the legacy (RV-12) and current (RV-12iS) KAI:
- RV-12 Section 35
- RV-12iS Section 35iS/U
