Replacement transducer for Fuel Mizer
Tom Horne
Active Member
I have a Fuel Mizer (equivalent to Northstar F210), but the sender is inop. I see this is a common problem. In the plane I have it's the only size display of fuel flow that will fit in the panel location it's in. Has anyone replaced the failure prone sender on this fuel flow meter with another type, like a red cube or Floscan? And if so, how does it work?
Tom
Transducer
Yep, Mike I saw all the failures in my internet research. I don't think I can fit another one in there. Maybe I should go to fuel pressure at the flow divider instead as an indication of fuel flow? I'll research that next.
Tom
