Yes I've removed it from a few of the bulkheads by popping the snap-in bushing out. Some of the bushing are not easy to get to and I'm curious how the cable got through the bushing in the first place which made me think one of the ends should come off.Pretty sure if you cut the snap-in nylon bushings in the fuse bulkheads off the cable you can pull the small end of the cable out through the holes in the bulkheads. That is basically the reverse of the installation procedure.
The bushing gets pushed into the bulkhead after the cable is inserted through the bulkhead.Yes I've removed it from a few of the bulkheads by popping the snap-in bushing out. Some of the bushing are not easy to get to and I'm curious how the cable got through the bushing in the first place which made me think one of the ends should come off.
I think it’s unwise to make general statements like this without knowing the OP’s plan for setting up the electric trim.I think you are unwise removing the manual trim. I've built several RVs (6,7 and 9 ) and flown them . I own and RV 7a that I built and decided to put electric trim after having an RV 6a with manual trim. Having flown both types of installation, I would say the feel of the manual trim is better than the non feel of electric trim. I can also mention when I lost all my electrics ( ie Dynon EFIS , radio etc, I found flying a plane out of trim ( not changeable) when in-the circuit and getting setup for landing manageable but would have added to the workload in a busy environment. Jeff
