Good Morning. I'm working on the internal of the left wing including the aileron bellcrank and pitot tube air lines and heating wiring. I fabricated a bracket to hold the pitot tube and heating wiring at the bellcrank so it can't inadvertently touch the bellcrank during flight. It looks and works great, but it impedes motion on the outboard most extreme motion. I believe it is outside of the normal range of motion because it's at the point where the aileron pushrod would start pulling again, but I can't find anything to say yes or no, so I wanted to ask the collective mind of VAF to see if you can confirm my thoughts. The attached pictures show the bell crank at the limit of motion due to the bracket I fabricated. Is this outside of the normal range of motion?
Thanks!
Thanks!
