SeanB
Just crossed 11.0 hours on Phase1. Aerosport IO-375, low compression. Remote/larger oil cooler behind number 3. Shutter to choke….not used yet! Getting ready for a total oil change (oil, filter, finger screen, analysis). Continuing with Aeroshell W100 oil. Any other suggestions as I proceed? BTW, motor is running Great! Can get 440 on take off, but easy to correct with nose down. Level flight is about 1250 EGT with 380 CHT. All within 10 degrees. Oil stays about 190-195 no matter what. Just now tried LOP. 6.2 GPH, 311 CHT, 1400 EGT, oil same. Not hardly burning any oil. About 156 kts true. Okay????
