Old HSI - help needed
pczar3
Patron
I thought if anyone could steer me in the right direction it would be this group! I have an HSI-100S-1 (Narco/Castleberry) that needs an overhaul. I have checked a few instrument overhaul facilities but have not been able to find a US facility. Does anyone out there have any clues or recommendations? The bearings are starting to get noisy. Thanks in advance for your help.
Paul Czarapata
RV-6A N694BP reserved
Gyro House
Just a quick word here.
You say the unit is "old".
A lot of "old" instraments used radium, glo in the dark, dials.
Gyro House wont work on these------Calif state law they say.
Been there, done that.
They do sell re-conditioned and yellow tagged stuff also.
Good shop.
Mike
May be trash can it?
pczar3 said:
I thought if anyone could steer me in the right direction it would be this group! Thanks in advance for your help. Paul Czarapata
I have to make some assumeptions and not sure what your budget, mission (VFR/IFR) and preferences are but here is my advice.
Not sure if you are committed to the OLD HSI, but you may end up spending a small fortune to get it repaired and find it's time to next failure very short or it may never really perform very well again, ever.
I had a bunch of old gyros, T&B, AI, DG, which I had overhauled. These where old instruments and it was not cheap to put new bearings in them and have them overhauled. I found they where marginally stable after having them worked on. I had the T&B in 3 times and AI in at least twice to get it close to working OK.
My suggestion is consider biting the bullet and look at the GRT EFIS ($6,000) or the BMA G4 ($4,000), both have HSI compass rose displays and accept nav input from a VOR/LOC/GS and of course GPS. My feeling is you don't need a DG or HSI.
Many handheld GPS have a quasi-HSI type display if that is what you are comfortable with, but think you will soon forget the HSI display format once you get accustomed to the EFIS displays. I assume you plan on flying IFR?
A Dynon EFIS ($2,200) is bargain priced as well but they are only flight instruments, attitude, direction, airspeed, altitude, vsi and so on. They don't have a bootstrap to nav data.
The nice part of all these electronic instruments is you will not trash them when you do aerobatics. I like to do rolls and loops. What is the wisdom of trashing your mechanical gyros doing Acro and than launching into sold IMC?
Thanks for the replies. The only real problem is the bearings get noisy for a few seconds on spin up and it does meet the drift rate on the bench. (without the slaving hooked up). It is a very clean unit and the budget just won't handle too big a hit right now. I'll call the gyro house on Monday and see what they say. Thanks for the help.
Paul
