Frankmali17
Member
Hello RV Pilots. On a recently purchased RV-7, with a Lycoming o-360-A1D... i have an oil leak I am not sure how to best handle.
I am going to attach a picture, hoping that someone here will recognize what I'm talking about right away.
Above the oil filter, is a tach sensor/sender.. .I think. and it looks like oil is leaking out at the connector or back of the black cylinder..., not where it goes into the accessory case on the engine, where the silvery thread cap is. I think this is what give the tach signal to my Dynon D180 ?
This causes oil to leak and drop onto the filter... then gravity makes it run down the side of the filter.. and eventually drips/blows onto the firewall and hoses/wires/things bellow.
Is this something pretty common? Should I contact Dynon for such a sensor? or Can someone point me to where I should look for one?
Thank You in advance...
