I also have the NOCO Genius 10 and it works magic. I don't use it to maintain my PC680 though because I fly often. I will use it while doing avionics work, etc, in "12V Supply" mode...provides a constant regulated voltage. It does have a 12V repair mode for sulfated batteries, which you should never need if your alternator voltage is properly regulated
I had a vehicle parked up in Door County (3D2) with an AGM battery in it for sitting long periods. Last fall I forgot to disconnect that battery and the next time we were there, the battery was complete dead. Even after a jump start, and 2 hrs of steady 14.4 volts from the alternator, it would not charge. I put the NOCO charger on it, and NOCO was able to put a charge on it, then I ran it through repair mode. Battery is probably good as new, albeit with degraded capacity...not a big deal in a car
