Mobil 1 ATF brake fluid regret?
TheNewGuy
Active Member
Patron
Lots of threads here about using Mobil 1 ATF, and most of the comments seem positive. I'm curious whether anyone has had any negative experiences with it. I'm asking because I already have a large jug in my garage and would prefer to use it instead of MIL-PRF-83282 if there are no significant downsides.
Large jug....? Has it been opened? Very important to keep moisture out of the brake system. It doesn't boil off like in an automatic transmission.
Given the decades of successful use of Mobile 1 ATF as a brake fluid in experimental aircraft, I doubt you will hear of a bad experience that can be attributed directly to the fluid. I’m betting that the responses will be echos of the positives above.
A few might chime in knocking it as not being a proven aviation hydraulic fluid that is certified and bonafide…
Hopefully not too much of a thread drift. I need to bleed my brakes and am running low in 5606 fluid. An I mix the ATF with 5606? Thanks!
