I'm no airplane engine guy, I've just had heat related fuel issues that I've had to deal with. Take my observations with a grain of salt and let's hope that Larry weighs back in.
I will observe that, based on experience, if you have a fuel injected engine that is showing pressure variations while flying, the engine is acting up, and that's all corrected by turning on the boost pump, you might want to be prepared to conclude that your fuel pump is dying. I had that happen too, on my ferry flight home from buying the airplane several years ago. It was completely corrected by replacing the fuel pump. I've also had a period of wide variations in fuel flow, without any discernible engine performance issues, and that ultimately turned out to be a dead red cube.
