Hello all-
I’ve been trying to address the following problem for over a month now…
IO-540 w/ Airflow Performance fuel injection and FM-200
F-1 Rocket
Starts easily and runs well during taxi out, runup and in flight*
After landing on taxi back (5 minutes), idle is slightly irregular (+/-50 rpm) and varies without throttle movements.
Oil temp in these situations is about 210°.
Most concerning - On the ground when hot after flight, with any but very slow throttle applications, the engine stumbles and hesitates before accelerating. Or stumbles, then quits. Quick moves to idle induce large RPM sags to just over 600 rpm before eventually recovering to 750. Various mixture lever settings do not reduce the behavior (extreme rich and lean makes it worse).
I’ve played with idle mixture, and have it set so that it idles well at 700-740 with the mixture lever at mid-range, and rpm rises approximately 60 rpm when moving mixture to idle cutoff. I’m deliberately setting idle mixture a little rich because my home field is at 6,900 MSL, with DAs regularly at 9k and above on warm days. I want a setting that won’t have me too lean when traveling to lower elevations. I’ve tried readjusting the idle mixture after flight with the engine hot, and couldn’t reduce the adverse behavior.
Of note, I recently had the fuel controller and fuel divider overhauled by Airflow Performance. This behavior after flying is new since the overhaul of those parts.
All my flights prior to the overhaul of those components were on cooler days (35-65°), and it always ran well on the ground. Now I’m flying on 85° days and experiencing the issues above.
Of note - even since the parts were overhauled, the engine responds well in flight and in the pattern, even during touch-and-goes.
I’m wondering if there’s a maintenance-induced problem stemming from the overhauled fuel control or fuel divider?
Or fuel boiling in the lines because it’s hot under the cowl after flight? (No reports of this from builder/previous owner, though).
Thoughts?
* In flight, the only oddity is that cyl #3 EGT drops to 200° below the other EGTs (e.g. 1079 vs 1261-1288) at anything below about 20 gal/hr fuel flow. On takeoff and initial climb, when running rich to keep CHTs cooler, #3 CHT is in the range with all the others. Once I lean (even ROP) below 19 gal/hr, it drops, but still trends up and down with all the other EGTs. Once I’m on the ground at/near idle power, #3 EGT is right back in the middle of the other EGTs. I’m guessing that #3 is running rich for some reason, but haven’t investigated this issue further (yet). Only mentioned in case it provides a clue for the “poor idle when hot on the ground” problem.
Edited to add:
Ignition:
Slick mag on Left
Lightspeed II on Right
F-1 Rocket
Thoughts?
Edited to add:
Ignition:
Slick mag on Left
