Is this correct?
glenadavis
Active Member
Patron
This is a photo of my choke cable. Should there be a spring? Does this installation look correct. Tks
Can someone provide a photo of the choke spring installed. I’m not the builder. Thank you.
There should be one on each carburetor, and they both mount the same way.
Are they missing from both sides?
All of the engine documentation is available for free from the Rotax owner website.
If you are going to do any work at all on your engine, you should get familiar with the factory documentation.
