Ignition switch
jlfernan
I built another brand of aircraft. My master switch is a simple keyed switch used to power the aircraft and keyed to prevent unauthorized use. The switch has work flawlessly for over four hundred hours. One flaw it does have, is does not have any positive detents, the key turns very easily. This weekend while turning final I started getting some strange warnings from my EFIS. Turns out the key has started rotating towards the off position. All of this to ask what kind of ignition switch is used in the -12? I don’t want the one with on-left-right, just the simple on/off. Thank you.
On legacy RV-12 w/ 912ULS there is L & R rocker switches for CDI ignitions and a keyed rotary spring-return switch for starter motor.
