Good Morning. I've weighed in on this topic, but want to get the collective brain trust's opinion on it as well. I have a friend who deviated from the plans when installing the flap hinge. The directions are not great about build order or how to mount the hinge for the flap. In the directions, riveting the bottom skins comes before mounting the flaps. It even comes before assembling the flaps. He decided not to dimple the skins because he knew he would have to lay the hinge in place to align and drill later and wanted the hinge to lay flat. The problem came when he did do the alignment, now with the bottom skin riveted in place, he couldn't get the dimple die in place to dimple the skin and the support underneath. The two pieces were too stiff to get the dies in place, so he decided he could countersink the rivets. So the stack-up is the wing skin (.032) the flap support (.040) and then the piano hinge itself (somewhere in the .040 range or thicker). The wing skin took the countersink and it is all riveted together is 426AD3 rivets. Per the plans, this would have been dimpled and the hinge would have taken the countersink to seat the dimple. The main span of rivets (37 total) is in the condition described above. The remainder (9 total) are worse. They are countersunk in .020" sheet.
That's the backstory. I shared a few opinions/options with him.
