I am trying to guesstimate the foremost position for the rudder pedals.
The pedals are Control Approach ones so I don't know how much the guidance given in the instructions apply. I placed them such that their bar is where the center between two bars of the original rudder pedals would be.
This is the most extreme deflections both forward and back (the left pedal hits the firewal and the right one is at the maximum difference between the pedals).
This is where I estimated the neutral position (just taking the middle between the two extremes).
Does that look like a reasonable position? Should I move them back a little?
Ideally, I would sit and try. However, I would like to drill the stiffeners outside of the fuselage, before everything is riveted together. I am probably not going to use the foremost position also, but I would like not to drill the holes which cannot be used.
