Hi Folks,
have no idea if there's a problem or not. fuel injected RV7 nearing 100 hours with standard tanks sealed with standard proseal and nothing else.
i religiously drain tanks as part of every preflight inspection. never found water, but anyway... what i find everytime is some dirt or debris in the drained fuel. what you see in the picture is the collected amount draining both tanks three or four times. when you look close there are some small dark pieces, some are more bright.
i have the airflow performance fuel pump spaghetti that contains a filter with a quite large filter area and a bypass valve.
i fuel the left tank with AVGAS from the airports pump for mainly takeoff and landing. the right tank gets premium grade fuel from the local gas station for cruise flight. when i fuel the tank from canisters i use a special fuel funnel with fine mesh filter.
is what you see ok or should something be done?
thank you very much in advance for your inputs.
Kay
Kay
