I have AeroLEDs strobes in my wingtips. They recommended shielding the wires from the wingtip to the wing root, which I did. But, I ran the shielded wires in the wing to the connector at the wing root/fuse supplied with the Van's harness. I am not sure the wires from the wing root to the panel in the Van's harness are shielded. Will this be a problem? I ask because the wires in the harness from Van's to the strobe were not shielded. So, are the shielded wires I installed just overkill or do they actually have to be shielded all the way to the panel?
Also, there is an electronic filter in the left wing to protect the ADAHRS kit from strobe interference. Was this included because of the lack of shielding in the Van's strobe harness? If so, do I need it since my strobe wiring is shielded?
Lot of questions, I know, but this is an area I am most uncomfortable with.
