I am fitting up the horizontal stab for drilling but seem to have an issue.
Just eyeballing before even measuring, when I clamp the rear spar to the vertical bars the leading edge is nowhere near centered. To get it centered while still making contact with the vertical bars it has to shift left so much that it runs into the horizontal stab skin and still needs to go more.
If I pivot the leading edge to get them roughly centered, then I have a gap on the left vertical bar about 3/16”.
Any guidance or help would be appreciated.
And yes, I will be going back and re squeezing all the rivets on the stab.
There are a few I am going to replace as I just don’t like the look of them. Can really tell I was at the beginning of the learning process with this!
