GEA 24 vs GEA 110
Garmin Expert, I am building a set of Orca Amphibious floats. I have dual hydraulic pumps to move the gear from water to land. The pumps are going to produce greater than 200PSI while in operation. I have installed 2 UMA 1EMZK pressure senders 0-2500 PSI. I want to display the hydraulic pressure on the AXIS system. What GEA should I use? Also, can I customize the AXIS to display both (Hydraulic pressure 1 & Hydraulic pressure 2) ? Thanks for the help...
Mark Steffensen
Ball Ground GA
RV8A
RV10
Murphy Radical - In progress
RV15 - Next
