Garmin G3X with GPS 20A - FAA ADS-B Report is Blank shows on Flight Aware.
jackking123
Patron
Know about the IFR 1E-7 and that is set to IFR 1E-7. Current Garmin G3X firmware is 9.33,
I checked a few things, but drawing a blank (pun intended).
This is a RV-12iS with a Stein Air Wired Panel. At one time it got a good report 2 yrs ago. Checking it now the Public ADS-B report is blank.
In FAA report request there is Garmin GPS 20A choice which is what the plane uses. I have tried selecting not listed and putting in the note at bottom. I tried using GPS 175 or other Garmin GPS. No joy.
Transponder Config item I'm confused on, two lines:
RS-232 Port 2 NONE
RS-232 Port 1 ADS-B + GPS Format 1
