So, prior to takeoff on every flight, I religiously set my Garmin A/P, I enable FD, set VS, usually 500fpm, and set it to track Nav or Hdg, as desired.
Here is my issue…I take off and as I climb out I begin a steeper than 500fpm climb. Glancing at the G3X I see a higher rate of climb, it varies, maybe 600 or 800fpm climb. As soon as I notice the steeper angle, and before the speed warnings, I either disconnect and rearm. Sometimes I’m able to just rotate the up/ down wheel down a couple of hundred feet and all is back to normal.
Very perplexing, all parameters seem to be correct. Anyone with a Garmin 307/507 control unit have this issue?
