Ferdara
Member
RV14A Build, received Garmin G3x Panel, IFR Nav, vertical power pro, etc complete built ready to install by SteinAir. Using a Garmin GAP-26-REG-20/Garmin HEATED Pitot tube, with AOA Regulated. I received the packed from Stein Air for the Pitot tube/wire kit. Included is the Red, Blue and White Tubing and Blue, Black and Red wires. Black wire will be routed from the ground near the panel to the Pitot, The Blue wire I found the connection in the bundle behind the panel for the Pitot regulated info. QUESTION: The Red "Power" wire is shorter. Does this go in the wing or does it go in the fuselage? On one end it has a Molex Male crimped and the other end is bare wire.
