Greetings folks,
I thought I would share my findings of a recent issue that kept me from traveling to AirVenture this year.
After overnighting in Alabama last week, and at the start of the *second* flight of the day, the Autopilot (G3X Touch - GMC 307 Mode Controller) would not engage. Pressing the "AP" button would cause the "Bee-Boo, Bee-Boo" tone and a red "X" through the AP status bar. Cycling power to the AP servos had no effect. Same result pressing the AP option on the autopilot controller screen.
I contacted Garmin to arrange for replacement servos since mine were circa 2015 and subject to the AD/SB. (Service Bulletin 23038)
I removed and inspected the original servos today, and found the following corrosion inside the connector cavity on the Roll Servo GSA 28.
The corrosion appears to bridge the Trim In 1 & 2 pins (Pins 11 & 12). In my system, the Roll Servo is NOT connected to the TRIM Motor In / Out; no Auto Trim for Roll.
I suspect that the GSA 28 was sensing activity on the Trim Motor inputs and disconnected; this is expected behavior if the trim switches/coolie hat is moved. Or alternatively, the CWS input was being pulled down (corrosion around Pin 15).
Here's the interesting thing -- there's no visible means for water (or any other electrolytic fluid) to get to this connector -- it is located above the outboard wing access panel, adjacent to the aileron bell crank, and it is facing UP (it's looking at the underside of the top wing skin). The other odd thing, the D-sub connector on the harness appears to be a cheap-electronics-surplus type and not a M24308/4-x-F connector (F is cadmium plated).
Something to add to the CI-checklist I guess.
Cheers...
Cheers...
