Having iiratic oil pressure readings on my G3X from red X’s to normal and varying. Based on that, I have ordered a new oil pressure sensor (150 psi) 1/8 27 NPT from Aircraft Spruce that is listed as the sensor for the G3X (Kavlico). I have learned that there may be a different Kavlico sensor now recommended by Garmin but the g3xperts indicated that if it is a (150 psi) it will work. I think what I ordered is just like what I have currently installed.
Is there a difference in the sensor designated as the G3X sensor from Aircraft Spruce and a sensor currently recommended by Garmin? If so, can you tell us what the difference is? Thanks
