Flight Test Manual v1.0 W&B - CG
Dave S
I'm working my way through the flight test manual and ran in to a little discrepancy. In the FTM Flight Test Matrix, it shows that the recommended test weights and CG for Trim Check, the 4 stability checks as well as the runaway pitch trim check should be down with a heavy weight forward CG, and Light weight Aft CG.
How ever the flight test cards for the Trim Check, you should have light forward, and heavy aft. and the stability checks as well as the runaway trim should use heavy fwd and heavy aft configurations.
Understanding that these are recommendations, it seems that there is a printing error in either the cards or the matrix leading to the disagreement.
Anyone with a later version of the flight test manual know what the recommended loadings are?
