Sources for the above; high purity, siliconized, fiberglass sleeving?
I am aware that Tefzel does not need said sleeving, at least for the 22/24 apps. I'm not ready to go there for 10/12 links/
If you know of a convenient source for the raw material, sufficient size for 10/12 plus terminal fittings, would be appreciated. Material from the common on-line retailers is a bit scary to me. Good confidence in the source would be appreciated.
Let me know. Much thanks.
