There really are too many variables.
Mine also 9:1 but with a SP cowl, CAI and a hartzell 3 blade. It’s maybe got 285hp
Best power and light I can easily get 178TAS at 8k. But that’s thirsty so I rarely do that. I assume the extra hp roughly offsets the extra blade.
Cruise for me is more like 172 LOP.
At gross you can knock 3-4 kts off both those TAS. Higher is better.
I’ve no doubt Vans numbers are achievable with a stock engine and prop setup. The key is reducing drag. So a plane that is rigged as straight as possible - with as little as possible hanging off it.
Things I did to reduce drag: I have a blade comdat to get rid of the GPS antenna, a blade transponder antenna. A nice tight 1/8 spinner/cowl gap, SP cowl with the nose gear/exhaust fairing under the cowl and a plenum.
It’s hard to quantify what difference each of these make - if any - but I believe it’s definitely a game of incremental gains.
This is 50 ROP. In a hurry with a nice tailwind.
