Chris Scott
Member
I read the following FAA excerpts. What are the practical implications? I can't land in Nashville? The administrator must approve IFR certs?
(c) Unless otherwise authorized by the Administrator in special operating limitations, no person may operate an aircraft that has an experimental certificate over a densely populated area or in a congested airway. The Administrator may issue special operating limitations for particular aircraft to permit takeoffs and landings to be conducted over a densely populated area or in a congested airway, in accordance with terms and conditions specified in the authorization in the interest of safety in air commerce.
(d) Each person operating an aircraft that has an experimental certificate shall
(2) Operate under VFR, day only, unless otherwise specifically authorized by the Administrator;
