Dynavibe bracket photos wanted
Do you recall what bolt size fit that gearbox hole? I thought it was an M8 but it didn't thread
Sorry, I lost track of that detail. I took a brute-force approach to this and had a variety of thread sizes and lengths. I took the ones that worked and put them in a ziplock in the (borrowed) test kit.
I only remember the handfull of small hardware bags from Home Depot, so it was not a special or uncommon thread.
I believe it would be more accurate if you reversed the way you attached the transducer so it would be more centered over the engine.
It doesn’t matter, it senses the movement along the vertical axis. Left, righr, or center it all moves the same amount.
