Whatever the maintenance manual says. You should be looking there, not here.
The one thing FAA inspectors would be looking for when checking maintenance operations at the airlines was a CURRENT approved reference for whatever we were working on. For good reason.
Thanks guys! I'm referring to the bolts acros the top center along the length of the engine. As shown in this photo, where i have to remove and reinstall those bolts to attach the forward and aft baffling center brackets. I just want to make sure that torque them back correctly.
And i just looked carefully at vans drawing OP-44 which says "NOTE: Lycoming torque for a 1/4 case bolt is 96 in-lb".
