My fuselage is still on a rotisserie. The F-01471 Fwd Top Skin and Canopy are not on yet. This allows easy access to the area between the panel and Firewall. I have been installing my AFS/Dynon HDX Advanced Panel and wiring. Routing and organizing the wires and harnesses is a challenge but made much easier by the easy access with my current setup.
Now I'm thinking I should install the five control cables which go thru the firewall while I still have the easy access. That would pretty much complete the work behind the panel. But I'm not sure of the problems that may cause when it comes off the rotisserie and it's time to install the engine mount and engine. Am I getting ahead of myself or does that sound like a good plan?
