I have a Yeasu handheld that I would like to connect to the Garmin GMA 245 in my RV-12iS as "Com 2". It looks like a fairly easy job that will require a shielded 3 conductor 22 gauge cabe and one unshielded 22 gauge wire for the push to talk along with some male high density pins. I have the wired lots of this sort of stuff from scratch but have not opened the connectors that came with my wiring harness. Has anyone done this and if so, anything I should be aware of?
I plan to cut the headphone adapter for the Yeasu for connection or just use some male headset plugs with it. I have an antenna to install on the top of the tail cone.
Thanks!
Henry
Thanks!
Henry
