Check the specs. and the installation instructions
RG-58 is not bad stuff ... you can argue the PVC composition vs. teflon(?) for RG-400, but the performance differences are quite small.
Co-ax specifications are here...
http://www.nemal.com/Catalog/30.pdf#search="rg-58 specifications"
Garmin, in their 430 installation manual calls for GPS antenna cable that has less than 10 db at 1.5 GHz.
The above spec. sheet has RG-58 at around 40 db for 100 ft., but at double the frequency of 3 GHz.
Even at this higher frequency, 10 ft. of RG-58 and a couple of good connectors will meet this requirement, which is good enough for TSO'd installations.
The GNC 430 installation manual has NO restrictions on cable length for COMM, VOR, GS and GPS cables, though they do suggest that the GPS cable be kept to less than 40 ft. - their actual requirement is the 10 db loss.
At the lower comm/vor frequencies, RG-400 is around 4 db loss per 100ft. at 100MHz, while RG-58 is around 5 db loss per 100 ft. - not really much difference for the above cabling.
Transponders - much more interesting...
The Garmin installation manual for the GTX 320 has some specific requirements, which dictate a better co-ax cable.
The antenna must be 3 ft away from the unit - note this is not a cable length restriction, but a straight line distance requirement.
Garmin does have a good electrical theory for this, it is "to prevent RF interference" - direct transmission through the air of 1 GHz high power pulses apparently can exceed their shielding of the GTX-320 box[/I][/B]
There is a 1.5 db at 1.09 GHz (much tighter than above) total loss (includes connectors) requirement for the cable.
RG-400 isn't that great, and if you use it, you have a maximum length of 8.8 ft.
For longer runs, you need better co-ax - RG-304 is 12.5 ft max. - RG-393 is 17 ft. maximum. - these numbers directly from the installation manual.
This is actually important for us, since the ELT and Transponder installations are required to be TSO'd (or to an equivalent specification) per the FARs
From this EAA web site...
http://members.eaa.org/home/homebuilders/faq/1Equipping a Homebuilt for IFR operations.html?
The requirements for transponder equipment and operation are found in 91.215, which has this to say:
(a) All airspace: U.S.-registered civil aircraft. For operations not conducted under part 121 or 135 of this chapter, ATC transponder equipment installed must meet the performance and environmental requirements of any class of TSO-C74b (Mode A) or any class of TSO-C74c (Mode A with altitude reporting capability) as appropriate, or the appropriate class of TSO-C112 (Mode S).
Note that, while it is required that the transponder equipment meet the performance and environmental requirements of the applicable TSO, it is not required that the equipment be manufactured under a TSO authorization. In theory, this means that you could actually build your own transponder, so long as you can document that it meets the requirements of the applicable TSO. However, the easiest way to be assured that your transponder meets the requirements of 91.215(a) is to install one that has been built under a TSO authorization.
So, the best way to meet the TSO requirement is to buy TSOd equipment (all transponders are) and to follow the manufacturer's installation instructions.
Check the installation instructions for the specific equipment you have. Check the specifications of the material you are using. Garmin is quoted above, your equipment may vary...
Good connectors and good solder joints at these connectors are probably more important.
gil in Tucson
