I need to paint one freshly skinned elevator. I have some R-M EP589 which is a chromate epoxy primer, and have used this in the past on aluminum parts. I am tempted to use this on my elevator.
I purchased some PPG MAE Acrylic Enamel from the local store - the only place around who can mix the color match I need. Here are my questions:
Can I use the PPG directly over the R-M primer?
Is there a product I should use between these two?
Should I forget about the R-M and use a PPG primer, and if so, which one?
Any help I can get with this will be appreciated. This is not a show plane by any means (otherwise I wouldn't be spraying this myself!), I just want the paint to stick.
